Hey does anyone know a loop hole in the califonia dmv for a small block conversion for an s-10.... as far as i can read there isnt one... any one go one threw?
onelowmini
In California I believe you can upgrade but not downgrade meaning if you have a 96 s-10 you can put a newer motor in it but not an older one. I know it used to be that way but not sure how it is now.
simple-pleasurez
just claim its out of a newer truck. as long as it still passes smog it should be ok
TADILLAC
its a 750hp small block... theres a 6-71 stickin out the hood.... smog isnt an option lol
simple-pleasurez
get another s10. switch vin numbers. illegal but....
tooleyhc
Find a diesel! Diesels don't get smogged.
Too bad S-10s don't come in Diesel tho... HA!
ShakinPlates
slap a doner motor in, run it thru the smog then swap. Just dot drive it down the road
marcus760
register it in az. or find an illegal smog
BigRich
throw an lt or ls style motor in that bitch, use all the stock crap form the new motor and let er buck! as long as its newer than the s-10 you shouldn't have a problem.
TADILLAC
ok the thing is alread built so the get a different motor is just out of the question....
i still have the stock 4.3 i can put in it but then what about exhaust and shiznet... this is going to be expensive and a pain in the ass! oh and im not running the stock wireing harness so the computer for the efi wont work
