Ford Trucks \  Will these wheels work on a ranger?
Ford Trucks Make Specific
views 251
replies 3
following 2
bagged92   +1y
Edited: 12/29/2007 1:51:59 PM by bagged92
Ive got a question for you wheel guys, i know the lug pattern is the same, but will the offset of these fit well on a ranger, or will they stick out. im plannin on 18x9 for the front, and 18x10 on the back, or would it be best to run 18x9s all they way around, here is a link to both widths
http://www.americanmuscle.com/blsawh1.html
http://www.americanmuscle.com/blsawh.html
bagged92   +1y
its a 98 2wd by the way if it matters
dakotahq   +1y
They'll fit just fine...the only thing you'll run into is the front center cap probably won't go on, and you may rub a little on the front. To clear the dust cap, you'll need a 7/16 spacer on the front. The rear will be fine with a 10" wide wheel, just don't plan on tucking it...check out www.rangerpowersports.com for more info on this, its an all ranger forum, and this gets brought up quite often...
bagged92   +1y
cool deal man, i appreciate it
