Mini Truckin General \  where to get viair rebuild kits and leader hoses
views 138
replies 5
following 5
tuckinlugs06   +1y
where is the cheapest place to get viair rebuild parts...and whats the best way to get that stuff viair puts in the bolt heads out ...and also on the york comp. what size fiting fit the 2 ports on the top i cant find anything that match that tread
TRUKBLDR   +1y
talk to mike at GRAVITY WERX . COM or SSD
tuckinlugs06   +1y
ssd is sold out
draggin04   +1y
grant kustoms
Madness   +1y
Easiest way to get the stuff out of the bolt heads, Small drill bit, go to the bottom, the rest will crack out and come out in chunks, very simple. When you need a Viair Leader hose or rebuild parts cheap, Call the guys at Minitruckin.net 1-877-209-8179 the Leader hose with check valve is $15, and the compressor head is $10, Piston assembly is $30 and that comes with all of your seals too. and new bolts! Dont' throw that shit away, rebuild it!
slammedxonair   +1y
i can get the rebuild kits for you for the viair. as for the york onboardair.com sells the tube o fittings for the ports that stick up out of the compressor, if you have the flat kind of york i can get you the fittings for those. also i have heard of people just running a 1/2 inch npt tape in side of the fittings that stick up on those kind and just tapping the inside out rather than buying the tube o fittings. brian@illusivefabrications.com
