Mini Truckin General \  Guy that machines nissan spindles to fit yota hubs
views 174
replies 9
following 9
trayfoe   +1y
Anyone know who he is, I had his name a while ago but lost it. Thanks in advance!
TwistedMinis   +1y
Jon, Laynrockers.
optikal20   +1y
when i was ready to get mine done, i e-mailed him a few times about it with no reply so i don't know what that was about.
trayfoe   +1y
Edited: 1/9/2008 4:46:24 PM by trayfoe
yeah I emailed him a wile ago with no luck, anyone know if he still does this? Or anyone else that would?
TwistedMinis   +1y
This is the addy he used when he sent me some emails recently.
biguglywagon   +1y
You can get the same results by changing the races in the hub. You need races the same outer specs as the toyota hub and inner specs as the nissan bearings. you will also need to space out the caliper alittle. Not trying to jack your thread, just offering another solution.
unusualfabrication   +1y
Laynrockers is the guy to see. Great guy, great work! If hes like the rest of us that work in machine shops hes busy all the time so he might not get back to you right away, but he will get back to you.
LaynRockers   +1y
Sup, I use 2 email adress laynrockers@gmail.com I do not check it as offten but if you email me at laynrockers@bellsouth.net I check it at least everyother day. I get so many emails about 5lug conversions it is hard to keep track. But if anyone need some work done let me know.
Corry Lewis there is a reason I machine the spindles to accept a toyota hub CORRECTLY! There is no shimming of the caliper and it all bolts up like factory. When you shim the caliper the bearings are not seating in the back and will wear a groove in the spindle and break them or will lock the bearings up on the spindle. I have seen both happen due to using some special seal. I have always gone by "you get what you pay for" I had to learn that the hard way when I was younger. So if anyone wants to spend $10 for new seals go ahead, and when you have problems give me a yell I will not have any problem fixing it for you, nor will I have anything negative to say about it.
I charge $115 shipped to machine the spindles to accept a toyota hub correctly.
gettwisted07   +1y
what exact year toyota hub do you use on a nissan spindle?
4uh8rs   +1y
JOHN HAS DONE WORK FOR ME AND SEVERAL FRIENDS IN THE PAST...IT HAS ALWAYS BEEN TOP NOTCH AND AS FAR AS CHANGING SEALS JOHN IS 100 PERCENT CORRECT..PAY THE 115 NAD GET IT DONE RIGHT
