Page 1 of 3
Air Ride Suspensions \  air bag QUESTIONS
air bag QUESTIONS
Air Ride Suspensions Q & A
views 497
replies 25
following 19
vincer   +1y
SHOCK PLACEEMNT..HOW DO U FIGURE THE "BEST" LOCATION UP FRONT AND IN THE REAR..ALSO WHEN I LET MY TRUCK DOWN..IT HITS REALLY HARD...WHAT CAN I DO OR IS IT JUST ME ?( I DON'T HAVE ANY SHOCKS IN YET ) ANY HELP WOULD BE GREAT!!!
Twisted Galant   +1y
the shocks will help with it dropn so hard. Basically find a good clear spot to mount them. The more out of the way and the more up and down they are the longer they will last
vincer   +1y
BUMP
slammedxonair   +1y
you could also go with slow down valves on the dumps if its dropping too fast for you
vincer   +1y
BUMP
Master Fabber   +1y
I maybe an idiot, but what does bump mean? How about typing thanks guys.
vincer   +1y
SORRY TO MAKE YOU LOOK LIKE A F@#KING IDOIT , BUT MAYBE ITS JUST ME...I THOUGHT "BUMP" WAS A WAY TO KEEP THE THREAD IN THE TOP "TEN" AND ON THE MAIN PAGE SO EVERY1 COULD SEE IT AND MAYBE RESPOND! AND AS FAR AS I COULD TELL NO! ONE! ANSWERED! ME! SO WHO DO I TELL THANKS?...BUT HEY TO ANY ONE THAT ANSWERS ME OR DID...MANY THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!
simple-pleasurez   +1y
bump does mean back to the top or front of the page. so does ttt (to the top)
vincer   +1y
TTT
pootytang   +1y
i've always seen it as easiest to figure fronts when the fenders are off if ya want to go that far, then you can have the truck set at ride height, figure half travel of the shock and locate the outer most part of the lower arm you can connect to while turning the wheels both ways. then raise and lower it and turn the wheels(as much as they will when layed out). also make sure the truck still lays out, sometimes a small shock does not have enough travel to allow even when set at half travel. i've even mounted them to the uppers in space constraints. shocks will slow you down a bit in the back but the front being heavier its never seemed all that different. i've used metering valves, also i've swapped dump valves for smaller ones. shocks will definately make a difference in the back.
