Ford Trucks \  20mm on body drop f150
Ford Trucks Make Specific
views 210
replies 7
following 6
dortonracing   +1y
will 20mm offset fit on a bd f150 fit they are 23's. also does anyone know what i have to do to keep the a/c.
DooredFord   +1y
depending how much you BD it should be able to keep the A/C, but dont take my word on that because I dont have mine.
Also 20mm will be tight even with rolling the lip, shorten the axle or get a bigger offset. My 22's with 255/30/22 are 18mm, and had to shorten my axle 3" or 4" cant remember what it was. Also you need to raise your upper arms 2" and pie cut them so your ball joints dont bind, and get rid of the ridiculous camber issues.
dortonracing   +1y
i think we body drop it 3-4 inches cab is lying on the ground. The probably im having with the ac it the tire coming inside the cab where the blower motor set. i have to tub the front quiet abit for the 23, if it wasn't for that i wouldn't be a probably. anyone know of a smaller blower motor or relocated it?
Master Fabber   +1y
I actually have an aftermarket blower motor in mine from spal.com They actually said it was the one that usually goes in the saleen s7? It is a little louder than stock but was easy to remote mount. Hope this helps.
dortonracing   +1y
i have belltech 2' drop spindels. does anyone know if they would make the tire wider up front? acting like a wider offset
Layumon22s   +1y
i know that you can get an a/c blower out of an aerostar van, that is what I almost did but was able to beat mine into place. you can look into an a/c for vintage cars they are normally pretty small but usually pretty pricey, when I looked it was around $1000. www.vintageair.com
thebagged1   +1y
no a/c here... ny dont get that hott... i like vintage air expect its heafy price... but ac isnt for me
chris03hd   +1y
Joel, post or send me more pics of your '89 for sale..
