Headliners
13 following
gkellison46@gmail.com's avatar
Headliners
truck action's avatar
truck action
Anybody change out theirs?? Want to redo mine ,is a bow type now,stock. Want to made a hard panel type.
livnthelowlife's avatar
livnthelowlife
yea i would like to do the same ,but if you did a traditional bd everyones heads will rub your fabric off.might be better to sew to the existing headliner
standardbyker88's avatar
standardbyker88
why not just glue to the factory headliner?
truck action
Stock my year is a bow type,wire hangers,in 4 or 5 places!,Sits just off the roof!! Want to do like later model trucks & cars,material on a padded panel!
fatman's avatar
fatman
mine was the wire and bow but i got a headliner out of a differnt truck that had a hard one in it it was only 100 worth every penny
standardbyker88
ive seen it done before on tv on some show. they took the body, flipped it upside down, laid down a bunch of plastic wrap and fiberglassed all over it. to make the board. plastic wrap kept it from sticking to the car. what about that idea?
truck action
No cab removal, truck is 90 percent done!
Will use sheet ABS plastic,glued to spacers glued to metal roof, & same material as seats over high density foam! Glue the edges like now too the roof lip all the way around.
maz duh's avatar
maz duh
Hey Gary, could you maybe do something like Joe suggested except with an extra roof off of a scrap truck? It would be easier to do that way too on account of only having the roof to deal with, just lay it across a pair of saw horses and go to town on it. If it worked well you could always build a mould from it and sell more. Probably be a few takers with how popular fiberglass interiors are these days. Just a thought anyways...
LaidNeon's avatar
LaidNeon
if you truck already has a headliner on it, you can pull off the old material & cover it with fiberglass resin & sand it smooth
wileypdf's avatar
wileypdf
some one could clean up taking the roofs from junk yard autos that have the wire headliners and just using them as molds for the fiberglass trick.
