tips.....for torsions
granth
alright, i plan to be bagged soon but i want to crank the torsions for shits if nothing else.
I know the concept, and I know HOW, but the two top nuts just wont move. I have tried a crescent on top and socket on bottom but they wont budge. is there a trick to this or just drench it in pb blaster and hope for the best? also.....they are regular threaded bolts, right?
waynehammer's avatar
waynehammer
WELL THEY SHOULD BE JAM NUTS ON THE TOP. IF U CAN GET THE TOP ONE LOOSE JUST LOSSEN THE BOTTOM ONE. I USED AN IMPACT GUN ON MINE
granth
i guess its a jam nut, i dont know. to me (it was dark) it looked like two nutes on top of each other. i will try the impact tomorrow with a crescent on the top nut.
smctoy's avatar
smctoy
There are 2 nuts on top of each other so they
wont come loose. I always used a closed in wrench to remove the top nut, wedged it up in there & then using a impact crank it down.
granth
alright. cool. thanks man. i will try and get it done tomorrow.
lucky_brew's avatar
lucky_brew
Edited: 3/6/2008 7:19:51 PM by lucky_brew
its a jam nut. i thought we already went over this texting over the phone. hahahaha. loosen it and it will lower the fuker but- if you simply loosen it then the hanger will hang down very low and rub on everything. take it completely loose, remove the torsion bar then respline it. turn it a 1/4 or so to get the bracket facing upward then install it. if you simply get it loose the bitches will bend and fall out while driving...
as far as the rear leafs (i know you gonna have questions there too) take out the overload spring (the one thats not connected to the hangers) throw it away and then flip the bottom leaf over. that will de-arch them a bit so you wont need as many blocks! i might not be up on bags links and tuckin 28.4" rims but im all over this shit man!
fatboysS1O's avatar
fatboysS1O
do exactly what Lucky said. he is spot on.
lucky_brew's avatar
lucky_brew
^ hell yeah! cause i know my old school shit homeeeeeez!
granth
you suck at yahoo messaging.
greenranger 23's avatar
greenranger 23
he sure does
