tranny swap
tuckinlugs05@yahoo.com's avatar
tranny swap
tuckinlugs06's avatar
tuckinlugs06
would a tranny of a 22r off a 88 body style fit a 93 22re? i know some one said its the same block but what about the tranny mount? the 2 link that was on this truck screwed up the tranny and the rear seal fell off so i need to eaither get the rear seals and a new rear part of the tranny or a new tranny ...
tuckinlugs06
if the trannys not messed up how hard is it to replace the rear seals? do you have to remove the tranny? also if i was to get the drive shaft shortened would this fix the problem
tuckinlugs06
anyone?
tuckinlugs06
can some one tell me where to find the trany plate to know what tranny i got?
tuckinlugs06
seth would you know where the id plate is on the tranny's?
tuckinlugs06
no one knows where the id plate is on the tranny?
TwistedMinis's avatar
TwistedMinis
I'm not sure they came with an ID plate. But you can usually tell the manuals apart by the number of bolts on the top that hold the shift linkage in place. I have a chart in my book I think that shows the bolt patterns and what transmission it is.
As far as changing the seal, its really easy. You remove the felt seal with a screwdriver, and then remove the oil seal with a specialty tool that you can get at any auto store. Called an oil seal remover.
Getting your drive shaft shortened may cause a whole other set of issues. You would be best to fix the issue that cause the problem int he first place.
tuckinlugs06
can u scan the pics about the bolts or tell me what is says
tuckinlugs06
well i got it narrowed down i think its a w something46 or 55 not sure but the id plate on the inside or the door has a w55 so mabe thats it hope it was never changed
TwistedMinis
W55 is the common 5 speed.
