seal sealer/body filler or weld it
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
what should i do one this tack it some more and use some filler or weld it up then filler ...this is only a filler plate
ahab's avatar
ahab
If there is a seem under that peice I would weld it as solid as possible. You bed floor is gonna flex allot. That will be the first place it will give.
tuckinlugs06
its weldes under it and the 3 cross braces under it are welded also this is just to cover the v between the to humps ..i was gonna tack it about every 1/4
ahab's avatar
ahab
I think that should work fine then.
OldSkool720's avatar
OldSkool720
I would tack it then fill
tuckinlugs06
ya im gonna tack it some more then just fill it
Severed701's avatar
Severed701
if your going to fill it.you need to weld it fully...regardless of what is underneath it...
tuckinlugs06
why its not gonna crack
waynehammer's avatar
waynehammer
WELL IF YOU HAVE THAT MANY TACKS ON IT WHY NOT JUST FINISH WELDING IT?
OldSkool720
hes gotta point
