Page 1 of 3
Ford Trucks \  returnless to return conversion
Ford Trucks Make Specific
views 896
replies 22
following 9
ixenn   +1y
Edited: 6/11/2008 5:05:46 AM by ixenn
Edited: 6/2/2008 2:13:17 AM by ixenn
I bought a truck that already had a fuel cell, external pump and a external regulator about 4 months ago and now im trying to get it running. ITs a 2000 Ranger and they had it hooked up as a return system but I can't figure out how they had it setup. Its a aeromotive regulator with two inlets and one outlet all which have cut hoses on them so they were using all three. I got my fuel lines ran to and from the rail but now i don't know where to put this regulator?? Do i just Tee it after the fuel filter and before the line and put a check valve after the filter and plug up the extra inlet? I need help! :
ixenn   +1y
to get you interested heres the best pic of the fuel cell.
ixenn   +1y
i need to get this figured out before wednesday.
VtecCrx   +1y
I honestly have no idea, but try calling the manufacturer?
willie_wonka   +1y
One inlet is from the fuel pump, The other is from the return side of the rail, and the outlet is to the inlet side of the rail. I am about 99.9% sure this is correct.
ixenn   +1y
but the 2000 ranger is a returnless system, where would the return from the rail be??
so if your suggestion is correct (but im still confused where the return is - im engine dumb sorry) i would go
Fuel Cell -> Fuel Pump -> One way check valve -> Fuel line to engine compartment -> Fuel Filter -> One inlet on Regulator -> From regulator outlet to fuel rail -> Return from rail to second regulator inlet. ?? lets hope so.
toreadorxlt   +1y
google
http://www.aeromotiveinc.com/pdf/13101.pdf
As per JBhill on RPS:
Fuel Pressure 441(63.9)+/-55(7.9) kPa
Engine Running/Key On Engine Off 441(63.9 psi)+/-55(7.9) kPa
Hook up FPR, hook up fuel pressure gauge, tweak regulator till fuel pressure is 63.9. Drive and enjoy.
bodydropped85   +1y
you MAYBE can run a rail off of a 97 down 3.0 and convert it to return system.
ixenn   +1y
i guess im being confusing, do i have the right idea? i know how to setup the regulation just not the order it goes in - unless what i just stated is correct. Also there is a line right below the inlet line on the rail right below the ERG valve anybody know if that is part of the fuel system?
tuckin eh   +1y
just buy a stock pump assembly and drop it in the cell. done.
