Page 1 of 3
Mazda Trucks \  ticking
ticking
Mazda Trucks Make Specific
views 668
replies 20
following 9
dragitall   +1y
when i start my truck theres a tick, like a bent valvebut iv checked them, their fine, i had a worn out lifter and i thought that was it so i replaced it. but it still ticks why? oh its a 88 b2200, 2.2 litter
Endless Kustoms   +1y
sounds like its bout to lock up to me check to see if u have any wore out bushings on ur crank from the piston ring arm....
kaoss   +1y
Mine clicks when it is a quart low on oil. Some Mazdas have mechanical lifters that are adjustable. I couldn't tell you which ones do and don't though. I think that there is some good stuff on mazdabscene.com about the different lifters.
dragitall   +1y
damn i hope not,i keep it oiled, its never over heated, i'll look n see.
dragitall   +1y
my lifters are in the rocker arms, you just pull them out by hand, idk if theyr called mechanical or not tho
xcpointx   +1y
My truck has hydraulic valve lifters, and used to get this tick.
You need to replace the faulty lifter (s)
When I did, it was like I had a brand new engine in there!
jdm customs   +1y
it comes down to prolly just the lifters. you can check the rods and such but its the lifters im sure. replace them all. i know they arent cheap but thats how you fix it.
corey0814   +1y
small exhaust leak at the exhaust manfold?????
dragitall   +1y
all my lifters are good,idk about an exhaust leak
xcpointx   +1y
yeah an exhaust leak DOES sound a bit similar. I got that at the moment.
Cover your tailpiple and have someone else locate the leak, and maybe weld that sucker up!
