What high build primers are you guys using?
12 following
dan48p@netscape.net's avatar
dan48p's avatar
dan48p
i'm trying to find something better than the shopline jp202 primer that i'm currently spraying for high build? it works allright for most jobs and when set over night it seems to be done shrinking. i use ncp271 at work but at near 200 bucks a gallon i can't afford to use this stuff on my own truck. i love it but it's just too expensive.
basically i'm just looking to see what you guys are using and how much you are paying for it. looking for a high build "filler primer" speed is not the main concern as i don't need to sand and paint the same day that i spray the primer.
let's hear your opinions
thanks,dan
ahab's avatar
ahab
I use evercoat featherfill G2. get it from eastwood.
supravan's avatar
supravan
i use evercoat filler primer n buff color and i get it for around $75 a gallon, shopline which was omni has a filler primer and it sands real easy and cant recall how much it is a gallon. i use a urethene primer 1st cause it sticks 2 metal real well and then some body work if needed and then filler primer but thats me
bodydropped85's avatar
bodydropped85
Edited: 8/18/2008 11:33:59 AM by bagged85
rust defender is what lil shop and the powerblock use. i know alot of people who use featherfill to. rust defender is about 100-140 a gallon depending on were u get it, and evercoat is 75 a gallon i think. ived used spies-hecker spray polyester, worked pretty good, but it was 69 bux a quart!
me and eric from little shop had a convo about rust defender about 2 weeksago. he swears by it. im gona try it when i do this vette at work.
dan48p's avatar
dan48p
who makes the rust defender? and can you spray it directly over metal and mud?
michael84
i used ppg omni high build throughout my truck unsure of the number on it i think its a 22 with 23 hardner dont remember?? but it works real well and wasnt too expensive i prefer house of kolors k38 but its too high so i went with ppg omni cause im poor and insurance only paid so much
bodydropped85
http://www.aircraftspruce.com/catalog/cspages/rustdefender.php
Z-chrome makes it, i think same company that puts out Zgrip.
TO
truckn outlaw
TRY WWW.SOUTHERNPOLYURETHANES.COM GOOD STUFF.....OR FEATHERFILL G2....OR U-POL PRIMER IS GOOD STUFF TOO.
turbotoyon19s
You can get rust defender at o'riellys . it sprays and sands easy
KEEF's avatar
KEEF
I like to epoxy prime all bare metal bodywork it then use a quality 2k urethane primer if its really ruff polyester it after bodywork then block the poly and 2k it
