What is the best tool for cutting sheetmetal
24 following
aaron@hydroholics.net's avatar
AON-4PumpedCL's avatar
AON-4PumpedCL
I'm looking for the best tool for cutting sheet metal. I'm not too concerned about cutting flat sheet metal where a shear would work great, but something more like wheel wells where it's not flat and you don't have much space. I've always used a sawzall, but it's just so bulky and I don't feel like I have as much control as I'd like.
Would something like a small air saw work well? Any suggestions? I see some people who have perfect cuts and I'm wondering how they acheive this.
ThanksAaron
jeebus @ mmw's avatar
jeebus @ mmw
I like using a small airsaw on stuff like that. It burns through it quickly, and the finish on the cut is nice.
Taylor
ahab's avatar
ahab
body saw. You can get pretty cheap.
kruzinlowkustoms
FOR A FLAT SHEET OR LIKE CUTTIN APART BODY PANELS? FOR FLAT SHEETS WE CONVERTED A TABLE SAW TO USE A CUT OFF BLADE WORKS AWSOME! FOR BODY PANELS AN AIR SAW IS GOOD OR A CUT OFF WHEEL
HarryBalls's avatar
HarryBalls
deff use a small air saw.....You will have alot more control for a straight cut and the panels wont flap around like when your using a sawz-all
jdauer02's avatar
jdauer02
if you dont have an air saw and are cutting a shape from a flat sheet you can also use a jigsaw with a metal blade.
fatboysS1O's avatar
fatboysS1O
body saw or plasma cutter
standardbyker88's avatar
standardbyker88
yeah, those little body saws are awesome. its basically a small handheld jig saw with a metal cutting blade on it. they work nice. not the fastest, but small and fairly precise. and no hot sparks that can make problems.
Uncle Fester's avatar
Uncle Fester
I love my little nibbler. It lets you do any shape
