Ford Trucks \  ford ranger bodydrop ?
Ford Trucks Make Specific
views 229
replies 7
following 6
framedranger   +1y
Need help! I bodydroped my 94 ranger 3 and 1/4 inches and the steering nuckle is at such a angle it wont turn its gets binded up.Is this a common problem...thanks
kaoss   +1y
you might want to check www.borgeson.com and see if you can come up with a creative solution.
dubDyme   +1y
i just did a 94 ranger, i swapped to a 98 front clip...i sectioned the steering column 13", pushed a brass bushing in the end, used a flaming river u-joint, some dd rod, and a firewall mounted support bearing. works fine. same thing should work for you. let me know if i can help.
cdubz   +1y
Edited: 9/28/2008 1:49:05 PM by zeroPSIzeroHP
Rick, had the same problem in my 90 ranger. Used a steering U-joint out of an 80's F-150.
bodydropped85   +1y
yup u have to redo the steering shaft, it just doenst magically work.
unusualfabrication   +1y
No reason to spend big bucks on Borgeson or flaming river stuff when you can get joints in town cheaper.
bodydropped85   +1y
i used ones off of an f150 on mine.
framedranger   +1y
Thanks guys I will see what I can come up with
