heres a new one for ya..
13 following
dflated19
i have a 94 pickup 5spd. i go to start it it goes click click. so i get it jumped. once i get it running i can turn it off.. then when i go to start it again it starts right up. about once a week i encounter this. finally, i couldnt get it jumped the "click" it made only got louder, so i had to push start it! embarrassing lol so i checked the starter and nothings wrong with it. The fact that i can start it right up after i get it jumped means something. i have no idea whats going on. Maybe a loose connection?
kaoss's avatar
kaoss
Have you taken the Battery to Autozone or Interstate Battery to get it tested?
dflated19
not yet, its a new optima red top. And it still happened when i replaced the old battery.
sadisticiron's avatar
sadisticiron
starters going bad. you can take apart the starter and realign the copper contacts in the solenoid or buy a new one. i recommend buying a factory starter. autozone, pepboys, etc are cheaper but they generally only last a few months
dflated19
are you for sure its the starter? i took it out, tested it, and the solenoid works fine.
sadisticiron
its very common. take the solenoid off and look at the contacts their will be cicular wear marks on them. once they wear down the contact patch gets smaller and smaller.
kaoss's avatar
kaoss
auto zone can test the starter and the solenoid
HoleShot03
Im with sadisticiron, change the contacts and you should be good.
nryota's avatar
nryota
sounds to me like the truck is completly ruined. you should just sell me the truck for like 100 bucks. lol.
low downin's avatar
low downin
Edited: 10/6/2008 9:16:52 PM by low downin
fusible link at the battery it had me stumped for a while. sounds similar
