What is the best stuff to use .. there has to be somthing that works permanetly..
ben_shady1
LOCTITE 569 is what I use.
maz duh
Teflon tape applied properly has always done me fine. Make sure you have the right tape for your application and that you are using good quality fittings. Its hard to get the cheap-o ones to seal up sometimes.
2fast4usdime
Thanks guys I m going to get the loctite And the fittings are all from pro hopper..
phatmx6
i have had trouble with the chrome prohopper fitting,,,might want to stay away from those
maz duh
Usually its the chrome that causes the issues from my experience. You can get an NPT tap or die to clean the threads before you assemble if you're worried. A friend of mine got a chrome air tank that wouldn't seal at the ports, once he cleaned the threads out it was good to go. Good luck to you on your project.
HarryBalls
"all fittings are from pro-hopper"
thats your problem right there.
2fast4usdime
That makes sense about the chrome I never even thought about that..
^^^you think that there fittings are crap what did you use??^^^
phatmx6
just use regular steel ones,,or like he said run a tread chaser thru them
jetts
use all parker fittings, the pro hopper chrome ons are garbage
