Air Ride Suspensions \  baggin a 63 impala
baggin a 63 impala
Air Ride Suspensions Q & A
views 3698
replies 12
following 11
layinlupo   +1y
Just picked up a 63 impala ss, i want to bag it on 22's, Which bags are the best for the older style cars without to much cutting, body and frame are all original, and doesn anyone know what offset i need to look at for the wheels. thanks
slammedrt   +1y
Edited: 12/23/2008 9:12:52 AM by slammedrt
i dont know how low you are going to get with 22s on front.You can go with slams or which ever your prefrence is and front and back brackets with little modification.Only thing that gets changed is the shock mounts. If you need anything you can email me at letloosecustoms@att.net and i can give you some prices. I have the offsets somewhere but not sure if i have them for 22s. hope this helps Jeff
layinlupo   +1y
i ultimate goal was to go 22's all the way around, but havent put it on lift yet and check, i really don't want to cut a lot because frame and body are all original, jsut has new paint, and interior. if i have to will go with 22's in back and 20's up front for that staggered look but i want to it lay even when dropped.
ImpOnAir   +1y
You can go with slams, i got my brackets from Air ride technologies, no cutting required. The offset for the wheels is about +12 or so, the 22's should fit on the back, but it will sit on the gas filler neck. The front will probably just require you to remove the inner fender wells. Hope this helps...
Revelations   +1y
I have an 66 with 22s...bags are really your choice, with 22s the problem is getting the right offset in the back. I went through Discount Tire and they called the wheel manufacturer and they gave me the right offset. I thought about going with 20/22 later until I love the 22s all the way around.
bigjon   +1y
Spend the money and get the air ride technologies stuff amazing fit, no modification. If you go with 22's all the way around you will need to cut the inner fenders up front and tub the gas door house. I did my friends 64 and it looks amazing but he decided to go with 20/22's because of the screaming deal he got through intro wheels! They came off of one of the show room cars got a great price wheels and tires!
impala_631   +1y
stay away from art,waste of money,and the 22s will fit and look bad,20s max IMO
noclrnce   +1y
You can get pretty low with it. Check out my 64 on 22s.
http://s321.photobucket.com/albums/nn399/noclrnce/
ENHANCEDAIRRIDE   +1y
We've done a few 58-64 b bodies, mostly on 17's and 18's one on 20's up front. Got a 60 Vert that were gonna mod a bit will most likely get 20/22 combo. The larger you go the les it will go down without cutting. Also to get low and ride low in back gonna have to tunnel under rear seat for driveshaft clearance. We have nice inexpensive kits that "fit". I really love the Air Lift Dominators on these cars awesome ride and lift.
Low_Smooth_Cool   +1y
never heard of our product being a waste of money? to get a product that is vehicle specific, bolt on, hundreds of hours of track and road time before its released I think we are priced just right... to each there own
