Toyota Trucks \  e-brakeMods??
e-brakeMods??
Toyota Trucks Make Specific
views 795
replies 18
following 17
91toylexus   +1y
has anybody had issues with the cables on each side getting in the way of the frame when laid out? Or keeping it from layingout? mine did so i just took them out. anybody got any ideas on different setups....like driveline brake.Or something of that nature.
corey0814   +1y
Edited: 12/14/2008 11:25:31 PM by corey0814
just a little re-working/relocating & it's fine. i think i just made the bolts for the clamps go a little lower on the frame, instead of smack in the middle.
menace   +1y
ditch it
Frame on the ground = ebrake
3day   +1y
Originally posted by Lowlowriderbike
ditch it
Frame on the ground = ebrakedont, sometimes a valve can leak up and bring enough pressure off your frame to roll. Just spend the time and make it work, just a little extra insurance.
skip1100   +1y
I made mine work on my 86 and i am glad i did. I ditched it on my 92 and i wished i hadnt now. its nice to have and very worth the little extra work it takes to keep it.
thacru78   +1y
If its a standard I would for sure keep it....automatic...I would ditch it.
maz duh   +1y
Don't ditch it, thats hack. Make it work and it will be there for you should all else fail.
HarryBalls   +1y
i just cut mine and welded the bracket higher up on the crossmember......
not hard to do and deff worth keeping
slammedcivicsi   +1y
I just tack welded the bracket to the frame, as opposed to bolting it on.
thacru78   +1y
So getting rid of ur e-brake is hack? So I guess tossing your airbag for a billet steering wheel is hack?....Shaving your doorhandle's is hack?...Shaving mirrors is hack? No rearview mirror is hack? I had to tub my firewall to an extent to where the is absolutely no room for an ebrake...Should i put it in the center console Camry style?
