Escalade Wheels on a Colorado
12 following
rokerdram@gmail.com's avatar
LaidNeon's avatar
LaidNeon
My buddy has a Colorado & just picked up a set of Escalade wheels. We know they center bore has to be bored to about 110mm or so so they will fit over the center of the hub. How would you guys recommend doing this??
railinisuzu's avatar
railinisuzu
Machine shop? Or redneck way: burr bit or hole saw!
LaidNeon's avatar
LaidNeon
lol, wasn't sure if this was a machine shop only recommended thing or not. whats the going rate for something like this??
dragginbottom
I had and 95' Isuzu that I put some Z71 wheels on, I just turned down the center of the hub so the wheel would go all the way on. I did it on a brake lathe, so maybe O'reilly's or AutoZone will do it for you???? They are kind of gay when it comes to shit like that though, liability and all.
jucieddime00's avatar
jucieddime00
Edited: 12/17/2008 10:09:21 PM by jucieddime00
nissan guys do it all the time with a router i think there is a couple youtube videos also
slamdtaco's avatar
slamdtaco
don't know if the site is still up or if it's safe. there were some viruses on it after the owner had some issues, but it is written in detail on nissanminis.com the exact type of bit you need for the router. it's very easy to do if you already have a router. all you need is the right bit.
LaidNeon's avatar
LaidNeon
Anyone know what bit to use??
granth
its a 1/8 or 1/4 straight bit with the roller. i remember reading somewhere about it. all it is, is that you have 2 grooved, and your shaving down the protruding one and the bearing catches the other wall so it stays consistant. google it, you should find it fairly easy.
kaoss's avatar
kaoss
I read that it had to be a carbide tip. They run about $30 at the welding supply store. My machine shop only charged my freind $80 for all 4 of his, so we just dropped them off instead of doing them ourselves.
N
neurotic
Im not to sure on the doing it your self part as to whats needed. But I know a wheel machien shop in my area does them for like 45-55 a wheel i beleive.
