trad BD on an 03 taco
19 following
vaperz_taco@hotmail.com's avatar
twiztedb22's avatar
twiztedb22
bout to get started on mine, anything in particular i need to know to do???
gorillagarage's avatar
gorillagarage
pretty straight forward if you already got the frame to lay your good.
twiztedb22's avatar
twiztedb22
aight cool, any pointers would help!
maz duh's avatar
maz duh
If your not currently z'ed consider it as an option first. It will make it less of a drop to lay rocker. Otherwise measure twice, cut first and don't rush it. The extra bits you can do will add up and show in the end and you will be happier with the result. Good luck with it, post some pix too.
1lonisn
We did a 96 taco in a weekend, and that was slacking off, for some reason it was the easiest body drop i have ever been a part of. as long as you know the basics you should be fine.
puddin06's avatar
puddin06
please make it lay rocker. Mine is to the pinch and wish it wasnt.
twiztedb22's avatar
twiztedb22
yeah im gonna Z the frame first off, ill post pics as soon as we get started! im gonna lay rocker with it dont worry!
lost cause's avatar
lost cause
You shouldn't have to Z a taco to lay frame flat
j_kinz's avatar
j_kinz
how do you get the frame to lay flat without a z. I'm wanting to bag mine but don't want to z it just yet anyway.
lost cause's avatar
lost cause
Shave & re-plate the front cross member and raise the rack and pinion up,.....then hit up Bio Max for his hand made spindles w/ uni-ball joint's (or use spacers between your lca and the spindle, but you'll most likely break your ball joints like I did )
My frame lay's perfectly flat on a 225/35/20 without a Z'd frame
