Toyota Trucks \  19" LS 460 wheel on a 91 Toyota truck
Toyota Trucks Make Specific
views 859
replies 5
following 6
LOMOFO01   +1y
I have not been able to get my hands on one of these yet to check the bolt pattern/ fit, but does anyone out there know if on the the Lexus LS460 19 inch wheels will fit on a toyota 5x4.5 bolt pattern? Do you have to mill out the center of the wheel for the hub? Any help would be appreciated. Please email me @ lomofo01@hotmail.com or post a reply on here.
Thanks,
Andy
neurotic   +1y
Well from what I can find the lug pattern of the lexus wheel is 5x120 which is not the same as 5x4.5
smctoy   +1y
Ok...that rim has the same bolt pattern as the Toyota trucks. As for having to mill it out then Im not sure about that. Im running 17-inch Lexus
IS300 rims on my truck & the rear went on with no problem, but I used 1-inch wheel spacers in the front to clear the hub & arm. It works great & it pushes the rim out more so it dont look odd lol! Here is a site that has
all sorts of factory rims & its where I found this info...
http://www.finishlinewheels.com/LEXUS/LS+SERIES/2008/A-74196U85/
91toylexus   +1y
lexus rims do have 5x 4.5 lug pattern mine are lexus as well as donnys. same thing he said.
project_77   +1y
wrong. the new lexus ls460's have a BMW bolt pattern which is a 5 x 120. Justin was right. they will not fit the toyota. Second, the bolts on a new lexus are a 14 x 1.5, toyota's are a 12 x 1.5. So there will be some play in the wheel with a smaller acorn lug.
2PUMPED   +1y
The new lexus ls460 is 5x120 the wheels will not fit.
