Page 1 of 3
Air Ride Suspensions \  K778 ball joint question
Air Ride Suspensions Q & A
views 3787
replies 21
following 9
unusualfabrication   +1y
Anyone know where I can find a steel sleeve for screw in ball joint K778?
TwistedMinis   +1y
Afco makes them, and Speedway carries them as well. It is just their "screw in lower balljoint sleeve".
supravan   +1y
i got mine from speedway motors
I looked at those but they only said for K727?  Are they the same thread pitch?
Sorry, they have one for K772 and K727 but I don't see one for K778 unless it fits one of the other thread pitches.
Oh, and this is an upper balljoint.
supravan   +1y
    ENLARGE IMAGE Starting at $7.99 Close [x]   Info This steel ball joint sleeve is used to build or repair control arms. Screw in style. Starting at: $7.99 Processing... STEEL BALL JOINT SLEEVE, SCREW-IN Item #: 91034812 Price: $7.99 EA Item Details: Fits 910-34323 upper ball joint 2.365" O.D. 0.265" Thickness 1" Height Select QTY: STEEL BALL JOINT SLEEVE, SCREW-IN Item #: 91034816 Price: $7.99 EA Item Details: Fits 917-20036 lower ball joint 2.497" O.D. 2.020" I.D. 1" Height Select QTY: Suggested Items Replacement Screw-in Upper Ball Joint Item #: 91034323 Item Details: (moog ref - K772 MOOG) Price: $12.99 EA Select QTY: LOWER BALL JOINT, SCREW IN Item #: 91720036 Item Details: (moog ref - K727 MOOG) Price: $14.99 EA Select QTY: PRO-BLEND ANTI-SEIZE Item #: 91016009 Price: $6.99 EA Select QTY: L-E ALMAPLEX VARI-PURPOSE INDUSTRIAL LUBRICANT GREASE, 14.5 OZ Item #: 4981275 Price: $8.99 EA Select QTY:
supravan   +1y
didnt see the k778, but i dont know what the other to numbers would cross over to. but if you havent fount any by tomorrow i can a local shop here and they can tell me what that K778 go's to and if they have any
supravan   +1y
chris i was wondering why you were using an uncommon ball joint? just wondering
TwistedMinis   +1y
I use the K778 also.   It fits in the larger sleeve, the one that;s about 2.5".
