need help first time bag 93 dodge dakota
9
93dakota
Edited: 2/2/2009 9:54:31 PM by 93dakota
this is my first time on here but i have a 93 dakota with 22's with a plus 35 offset to tuck now and i know for that the rear end will have to be shortened. i need suggestions with front and what bag setup to use please help. any info is welcome. im also trying to get this done before scrapin the coast and also doing motor swap form 3.9 v6 to either 3.18 or 5.9r/t motor have not made up my mind and it has 265/35/22 tires on it now i think that a 255/30/22 will work need heip please!!!!!!!!!!!!!!!!
Deluxe_D100's avatar
Deluxe_D100
Check out customdakotas.com for some info. Pm me I can try to get some pics of my front setup.
9
93dakota
--------------------------------------------- Originally posted by Laid_Dakota Check out customdakotas.com for some info. Pm me I can try to get some pics of my front setup. ---------------------------------------------thanks man im trying to get it done before scrapin the coast. and it has a 3.9 v6 trying to put either a 5.9 or 3.18 v8 in it did not know if that mattered.
Deluxe_D100
Im not sure if it matters or not. Mine is a 3.9. Either one of those motors will bolt right in. I'll be at scrapin(not w/my truck) so it'll be nice to see a Dakota there. I know there will be a bodied single cab there. Anyways, pm me, i can't see your screen name,
9
93dakota
i dont know how to get it to come on it just got a membership here this is my first time on here a friend told me about it but it is 93dakota and mine is a short wheel base regular cab. maunal 5speed someone that my buddy knows told me that it mattered if it was automatic or maunal to what u had to do but i did not know if he knew wat he was talking about.
Deluxe_D100
Sent ya a pm, go to community up top and drop it down. And click on open ims.
standardbyker88's avatar
standardbyker88
manual matters because of having to move the clutch master up for tire clearance. id say a small z is needed knowing dodge suspensions (crossmembers are always way lower than the frame), drop spindles, firewall tub, move the stuff above the tires up or over. i would keep the 3.9 in it myself. find an old used carb intake and swap to a 500cfm 2 bbl holley. pistons and yada are the same as the 318. they make cams and stuff for them too. rear is however you wanna do it. if you dont have wheels yet, id say go to the 87-90 dakota rotors and rearend to get 5x4.5 pattern. easier to find wheels.
jayslowlow's avatar
jayslowlow
Edited: 2/28/2009 12:23:48 AM by jayslowlow
Edited: 2/5/2009 9:12:08 AM by jayslowlowi am working on a 92 ext cab with a  318 right now. i z'd the front 2" with that done you can get around 26.5" of total rim and tire and get it to lay. i am gettin 20s. i just ordered my wheels  are a +45 offset and tires are 235/30. there is a guy on customdakotas who has same set up. i don't think your offset is gonna work. and as far as getting it to lay on 22's if you pie cut the arms. or do a bigger z then you could prolly do it. but i think you would have to tub the firewall too.
RB
Ridin Big Caddy
bump for a club member
9
93dakota
--------------------------------------------- Originally posted by jayslowlow Edited: 2/5/2009 9:12:08 AM by jayslowlow i am working on a 93 ext cab with a  318 right now. i z'd the front 2" with that done you can get around 26.5" of total rim and tire and get it to lay. i am gettin 20s. i just ordered my wheels  are a +45 offset and tires are 235/30. there is a guy on customdakotas who has same set up. i don't think your offset is gonna work. and as far as getting it to lay on 22's if you pie cut the arms. or do a bigger z then you could prolly do it. but i think you would have to tub the firewall too. ---------------------------------------------i am very uneducated when it comes to bagging something so could u tell me what a z is please.
