Easiest way to convert a mighty max from 6 lug to 5 lug
FluffyFreak
i gotta 89 mighty max im lookig to convert to toyota 5 lug and dropa 350 in. i would like to run toyota drop spindles if possible. so whats the easiest way to go about this short of using a toyota clip?
ShaveDnFlamed99
X2 I need this info too before I do the brakes on my '88 I'd like to switch to 5 lug if its cheap enough.
/7
///RELAXED 720
Edited: 4/28/2009 5:39:22 PM by ///RELAXED 720
IF i remember correctly they did a 5 lug swap tech article on Ernie's stock truck project in MT.....& again IF i remember correctly the yota hub bolted right up to the MM spindles..... now i could be completely wrong..... Max can tell you if my memory is correct ..........
FluffyFreak
thanx Kevin! ill have to look for that article o got it somewhere around here. id liek to see abiout running toy spindles too tho so i dont ahve to use AIM drop spindles!
Ive never had a single problem with AIM drop spindles, got em on three trucks right now and have used them for years in the past. just thought id throw that out there also lol
ShaveDnFlamed99
Thanks Ernie for the Info This will work for a D-50 I assume right? If so this just became my bible for working on this truck of mine!
slow50
d50 and mighty max is the exact same thing.
ShaveDnFlamed99
Thanks, I figured as much but everytime I assume something I get bitten in the ass no matter what the situation
FluffyFreak
thanx Ernie. will the way the steering is setup affect droppinga 350 in a max?
