Breaking into you're Mazda...LOL
slammeddawg92@gmail.com's avatar
mazrod's avatar
mazrod
I accidentally locked my keys in the Mazda last night and I am having the hardest time trying to get them out. I have a metal coat hanger and I know somewhere I read there's a certain way to bend it to unlock the door, but can't find the info. I dont have a slider so I can't push in the center peice and just climb through. any help would really great. My Autozone and Advanced use to sell Slim Jims but no more to many break ins around my area. any help would be great !  Post your ways to get in and I will try them and see if they work. thanks guys...
Uncle Fester's avatar
Uncle Fester
I found out the back window is just a pressed in seal around a edge.  Get something in between the body and the gasket and work it around the window will slowly work its way out.  Once you have it out just have to wrap some string around it and reverse process.  Good luck.Maybe someone else can explain it better.  Good luck.
mjavy7's avatar
mjavy7
...and remember to ALWAYS have spare copies of the key around.
bikerider
if you get a 12" steel rull or somthing similler you can slide it down betwen the glass and the wether strip on your door. You have to go in at the back corner of the glass follow the glass channel down to where the catch is . There is a bit on the catch you can push down on with the rull and it will open the door
mazrod's avatar
mazrod
Thanks guys for the tips. the last tip from BikeRider doesn't seem to be working. I got a 12' ruler going down the channel of the door where the lock is and I cant find any bit the lock moves but nothing happens ?  ?  ?
shagee2001's avatar
shagee2001
Edited: 5/10/2009 4:25:17 PM by shagee2001
Hotshot... check you IM's ... i sent you my phone number. I have shaved doors and no poppers...... i know how to get in. NEVERMIND>>> i forgot your door is locked. My locks are remeved.... what i'm hitting is the door handle thingy. But if the lock thing is engaged it wont help. I would just remove the back window or call a locksmith.
projekt94's avatar
projekt94
i once locked my heys in my truck at school. get a hanger and stick it in between the galss and door in the middle there is a latch that is to pop the lock. try to catch that latch and it shoulkd pop open the door.
iveverlowmazda's avatar
iveverlowmazda
i took a coat hanger straightened it out but left a hook at the end went threw the top of the door in between the seals hooked the door handle and slid the coat hanger to the back of the door while holding pressure on the hanger and the door handle and then slowly pulled and bam it opened but dont pull fast or you will pull the hook out of the hanger
laynwindows
use a coat hanger, i can do it in like 10 seconds. bend a hook at one end of it, and at the other end, bend a 90 degree angle, that is 90 degrees to the hook. that way you can know what way the hook is facing, and its easy to maneuver it. shove that fucker down there and go up and down and you'll see the lock moving and then you know where to concentrate the hook and you'll get it
bikerider
sorry bro my truck has no handels so the door is not locked thats how i can open mine with the ruler
