small block oilpan in my bodydrop ...NOW I HAVE A HEADER PROBLEM...
11 following
ssm@bigjohnsondesigns.com's avatar
idrgbdy's avatar
idrgbdy
Edited: 6/8/2009 2:36:43 PM by idrgbdy
i actually worked on my truck last night. got the motor almost in, and the damn oil pan is not going to work. anyone know what oil pan they are using?
oh, it's a '96 sonoma, traditional 3.5" bodydrop and i'm throwin in a small block.
9
94NissanLaysDoor
What truck is this engine going in?I dont' know about that pan specificly, But Moroso does make a shallow pan like that that doesn't ramp down Or check out chevy II oil pans..http://cgi.ebay.com/ebaymotors/CHEVY-II-SB-NOVA-RACING-OIL-PAN-283-350-SBC-SMALL-BLOCK_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem5ad0935b88QQitemZ390046374792QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesLike the one above
idrgbdy's avatar
idrgbdy
it's a 355 going in my '96 bodydropped sonoma.   that chevy II pan looks like it may work except the dip stick is on the drivers side and says you cant use it with power steering. guess those arent terrible problems. lol
9
94NissanLaysDoor
LOL, Tell you the truth, I have never had an issue with using a standard oil pan (like the one you drew) in an S10 square or new body!Thats nuts...Did you use the "bolt in" motor mount kit...Or build you own?
idrgbdy's avatar
idrgbdy
i bought the stealth motor mounts from that jags that run website. the pan is hitting the crossmember but the motor still needs to come about 2" forward.
4uh8rs's avatar
4uh8rs
have u considered sectioning the crossmember
idrgbdy's avatar
idrgbdy
ya it's an option, but i'd rather not if i don't have to.
Johnny O's avatar
Johnny O
I'm running a Hamburger's Performance pan, Trans-Dapt motor mounts and a 350 in my body dropped '97 S-10. Check out their pans.    http://www.hamburgersperformance.com/default.asp
idrgbdy's avatar
idrgbdy
--------------------------------------------- Originally posted by SSM-Johnny O I'm running a Hamburger's Performance pan, Trans-Dapt motor mounts and a 350 in my body dropped '97 S-10. Check out their pans.        http://www.hamburgersperformance.com/default.asp --------------------------------------------- those seem pretty expensive. but do you know which model pan you have?
Johnny O's avatar
Johnny O
1099 -SB Chevy (283-400) 1955-79-into S10 Swap- Drag RacingWET7 Qts.$288.87    picture and dimensions are here... http://www.hamburgersperformance.com/images_products/5410.jpg
