Air Ride Suspensions \  IRS out of a lincoln LS. Anyone used one before in there mini?
Air Ride Suspensions Q & A
views 1685
replies 18
following 12
j&jkustomz   +1y
OK.. I robbed an IRS out from a Lincoln LS..  It has low miles on it so I figugered I'd use it plus it was free..  lol.. And ways, Has anyone used one before? You see alot of Supra's, RX-7's and 300z.. Never really here much about a Lincoln LS.. I'm using it because it is the same lug pattern as a yota so my rims will interchange between each vehicles and its the most comon 5 lug.. But if you guys knows anyone that has one please post pics.. And any pics of Full frames with IRS will be very helpful..
slammedxonair   +1y
Not sure what the ls is like but alot of people use the mark viii rearends they are pretty much the same or similar to the t-bird and mustang cobra rearends
pugz   +1y
THE LS'S HAVE TOO MANY PROBLEMS.  ANYTIME U TAKE A WHEEL OFF YOUR REPLACING LUGNUTS AND STUDS FROM STRIPPING THEM. I WORK AT FORD, LS'S ARE POS'S
Jance Customs   +1y
---------------------------------------------Originally posted by pugzTHE LS'S HAVE TOO MANY PROBLEMS.  ANYTIME U TAKE A WHEEL OFF YOUR REPLACING LUGNUTS AND STUDS FROM STRIPPING THEM. I WORK AT FORD, LS'S ARE POS'S---------------------------------------------I like there full power heated and cooled seats! I put a set in my daily
pugz   +1y
the seats are fine. but the suspension is junk
j&jkustomz   +1y
Well "SUM BICH".... I had an option to get either one.. There was sitting next to each other and i just grabed the one closes to the truck.. I will have to see if I can get the other one as well.. Do you guys have any pics of one installed.. I just need to see if people used the control arms or made there on.. Any pics would be appreciated!
mr.ed   +1y
Are they both the same width? could you get the the measurement? Thanks Ed
20runner   +1y
I don't know what year LS you got it from, but the bolt pattern on the LS we built was a 5x108, NOT 5x114.3 like a Toyota. I'd double check the bolt pattern if I were you......
low mazda   +1y
yeah, I was gonna say the same thing. The LS has a different than normal lug pattern.
bodydropped85   +1y
also, its a jaguar made rear end just like the rest of the car.
