front clip
front clip
1lowrngr
i want to get rid of the i beams on my 87 ranger whats the best front clip to use? iv herd of toyota and a mustange 2?
mindlissmetalfab's avatar
mindlissmetalfab
Edited: 6/15/2009 9:53:25 AM by iLLblazer
Toyota will be your best bet. Mustang 2 kits are generally just a crossmember kit, which would be a pile of work to adapt to your ranger. With the yota, just swap frame clips.  84-95 toyota is what you would want.
1lowrngr
alright thank you and what problems am i going to run into?
bodydropped85's avatar
bodydropped85
Edited: 6/15/2009 11:38:55 AM by bagged85
mounting the steering up, but that can be acheived with universals. also the rails of the yota clip sit about 2.5 inches below the top of the ranger rails, so some good metal work will need to be done.
slammedxonair's avatar
slammedxonair
nothing wrong with mustang ii clips either setup will work great.
1lowrngr
thanks for the help dose any one have any pics of the process?
TwistedMinis's avatar
TwistedMinis
Edited: 6/16/2009 2:13:58 AM by TwistedMinis
I would probably narrow a Toyota clip a bit to match the stock track width, since Toyota's are slightly wider and will change the offset you need to run. I still don't like MII setups. For the amount of travel you would need on a BD Ranger, a MII just won't cut it. I would go Toyota or scratch built over MII any day. Clipping a Ranger would be cleaner too, just because of the frame design.
bodydropped85
well the yota rails by the control ars ar aboue an inch narrower then the ranger rails.
1lowrngr
thanks for all the info on the clip question today i noticed as i droped the back of my while i was driving there was aloud noise like somthing was rubing so when i got home i put my truck on jacks and i found that my drive shaft was rubbing on the rear of my body is this normal for it just being bagged?
I
insaneautoconcepts
Check this out if you need something more custom custom chassis's and clips
