Glass air tank???????
18 following
X
X
xgolferdude
Anyone know anyone who can tell me where to get one or who makes em???  I've seen a few pop up and I think there pretty cool...  thanks!!!
bigjon's avatar
bigjon
the clear tanks that I have seen are all plexi-glass whammy tanks for hydrolics that people have converted for use as a air tank.
X
xgolferdude
really well i had no idea...  oh btw what the hell is a whammy tank!!! lol
guiltybydesign's avatar
guiltybydesign
I think a clear airtank would do only 2 things... contain pressurised air and become filthy on the inside.
X
xgolferdude
well couldn't you run some time of filter? because I thought of that as well...  I just like the way they look in a sheetmetaled bed....
Don Shagwell's avatar
Don Shagwell
How would you rate the air pressure??
LWRD_FRK
Well if they are used for Hydraulics they have to be rated really high!  Most hydro setup, the pressure is about 1,500 to 2,500 psi of oil pressure, which should be about 500psi of air pressure.I would like to see one though that can stay clean using air! Even with an air filter or anything, air buils a lot of water, just imaging how the shower doors turn white do to water, I'm pretty sure thats how the clear air tank will get.
bigjon's avatar
bigjon
Pressure is pressure oil or air
simple-pleasurez's avatar
simple-pleasurez
---------------------------------------------Originally posted by bigjonPressure is pressure oil or air --------------------------------------------- thats what i was thinking.
milenk0
from my understanding, a whammy tank in a hydro set up doesnt keep pressurized fluid, just a reservoir for the pumps to pump. could probably throw a little CLR cleaner in the port of the tank, much like doing anti freeze in the winter.
