Mazda Trucks \  chevy 350 in mazda
chevy 350 in mazda
Mazda Trucks Make Specific
views 5805
replies 17
following 8
truk2low4u   +1y
im putting 350 in my 88 mazda and was wondering if any firewall mods had to be done to fit the motor and trans?and do i have to section the oil pan?
PartonsAutobody   +1y
thr tranny tunnell will have to be modified and the firewall will have to be modified to clear the distributer
truk2low4u   +1y
ok to clear the distributer should i c ut a hole or is it alot more intaled
maddawg   +1y
Edited: 9/26/2009 1:36:58 AM by maddawg
you don't have to move the engine into the firewall if you use a small cap distributor and a short water pump and mount the rad in the front of the coresupport,BUT!! I would HIGHLY suggest that you DO set your engine back into the firewall a few inches (the more the merrier) as this with give you a hell of alot more options to mount your external components by being able to use a long waterpump (i did not set it back and regret taking the easy way out , whichin turn cause more headache)i was able mount everything i wanted (ac pump , powersteering,ect..) but damn it was such a frickin' pain.you will also get better hood clearance by doing so (depending on how you set the motor).
maddawg   +1y
Edited: 9/26/2009 1:38:58 AM by maddawg
 http://image.minitruckinweb.com/f/8577612+w750+st0/0601mt_10_z+1990_mazda_b2200+engine_compartment.jpg here is the perfect example of what i am talkin' about. I reaaaaalllly wish i would have don'e it like this. look at all that frickin' clearance between the motor and radiator.he even has his rad mounted in the inside the core support and using a stock fan. damn i'm jealous!!!
dragginmazda86   +1y
I pushed my SBC a bit into the firewall and  notched the oil pan so the engine would fit under a b2600i bubble hood with only the inner bracing cut out.  Checkout my profile (the baby blue 86 b2000) theres some pics of what I went through. Let me know if you need more pics or have questions.
truk2low4u   +1y
thx rudy and david for all the help i wend ahead and cut my firewall to set motor back a few inches. next question is (prob a stupid one) there a way to use the stock mazda trans with the sbc??
dragginmazda86   +1y
I've never seen the stock mazda trans mated to the chevy engine before. I'm running a turbo 350 trans in mine.
truk2low4u   +1y
ok thanks again
maddawg   +1y
don't even try it.i have a 4L80E in mine.350 tranny is probaly the cheapest way to go.you might want to think about swapping the rear end also.i have a ford 9" in mine but i originally had the stock mazda rear when i did the swap.i litereally exploded when i nailed it and the tranny shifted into second gear. it would probably be fine with a stock motor and if you don't drive around like a mad man.btw i'm proud of you for diving in and moving the motor into the firewall.
