Body work and Paint \  I need a p sheet or mixing instructions for DCU2001
Body work and Paint Q & A
views 743
replies 4
gravity5   +1y
as stated above i found 2 gallons of dcu2001 and I cannot find a mixing sheet anywhere for this stuff.  I know its old but i believe it is sheet 156.  I really need this.
Thanks in advance.
alilbumpngrind   +1y
You got me man. I'll check our cabinets at work one monday and see if i can find an old tech sheet laying around. I know i threw away a bunch of old k38 and k36 tech sheets and don't know if i saw any 2001 sheets. Does it not say on the side of the can? You know what hardners it takes.
Streatch   +1y
I just used some of this a few weeks ago. i mixed it to the old sheets i had which put the ratio at 2-2-1, but it sprayed a little too thick for my taste. i just kept adding reducer til it sprayed the way i wanted. love using this stuff.
lotaco1   +1y
I Have the p-sheet Give me your email and I will scan it and send it to ya - Thats the best clear on the planet if its the orig. 2001 .
gravity5   +1y
Oh thank you so much, its evolwheels@gmail.com  I would really appreciate it.  I found another gallon so I want to use these 2 gallons up.
