98 ford ranger
kennethsonnier@yahoo.com's avatar
98 ford ranger
customforlife's avatar
customforlife
on a 98 ford ranger what tool do i need to flip the lower ball joints and tie rods? like what kinda drill bit and such.....and how much i would need to raise the uca's
im working on a friends truck and trying to get the front to lay right and also repairing the rear setup as well
msturg's avatar
msturg
no, the best way is to get djm control arms.  Is he trying to eliminate all camber or use his factory arms?
bodydropped85's avatar
bodydropped85
you dont. uniball the upper is the best way to go.
customforlife
---------------------------------------------Originally posted by msturgno, the best way is to get djm control arms.  Is he trying to eliminate all camber or use his factory arms? ---------------------------------------------he has the djm control arms and the front crossmember doesnt lay out hes on 17's with a some what big tire....im trying to get it to were his truck lays in the front and the rear will not screw up on him anymore. if it was my truck the yes i would be trying to eliminate camber but i dont know if he cares to do that or not.. on thee djm's the upper ball joint is binding causeing the front not to lay.
customforlife
Edited: 2/18/2010 4:19:21 PM by customforlife
---------------------------------------------Originally posted by bagged85you dont. uniball the upper is the best way to go.---------------------------------------------i realy dont know all that much about that?  and i dont have the tools to make uppers with uniballs on them
slammedxonair's avatar
slammedxonair
You should be able to lay out on 20s with DJM upper and lower arms. Do not raise the uppers, flip the tie rods, or flip the balljoints it will mess all your geometry up and create bumpsteer. Pull the boots off the DJM upper balljoints and make sure the balljoints are clocked correctly, they had a problem for a while with them being pressed in wrong. Check that before anything.
customforlife
---------------------------------------------Originally posted by slammed x on airYou should be able to lay out on 20s with DJM upper and lower arms. Do not raise the uppers, flip the tie rods, or flip the balljoints it will mess all your geometry up and create bumpsteer. Pull the boots off the DJM upper balljoints and make sure the balljoints are clocked correctly, they had a problem for a while with them being pressed in wrong. Check that before anything. ---------------------------------------------ok cool...he is also still using his sway bar and the sway bar brackets on the djm lowers are hitting the frame when layed out too
msturg's avatar
msturg
the sway bar could be your biggest issue, I can't say I have personally seen a 98+ ranger laying with the sway bar.  Also, check to make sure that he has notched the frame for the tie rod.   btw, I wasn't trying to be a dick, I read your question really fast yesterday and thought you were asking if you should, not what to use.
customforlife
---------------------------------------------Originally posted by msturgthe sway bar could be your biggest issue, I can't say I have personally seen a 98+ ranger laying with the sway bar.  Also, check to make sure that he has notched the frame for the tie rod. btw, I wasn't trying to be a dick, I read your question really fast yesterday and thought you were asking if you should, not what to use. ---------------------------------------------yeah i dont think the sway bar is binding out anything its the way the bracket on the djm lowers are that when he lays the truck out the brackets on the lowers hit the framethe frame has been notched for the rie rods too na man its ok i didnt think you were being a dick or anything
low99maz's avatar
low99maz
I raised my uppers raised the rack and shortened the lowers, with no major negative effects on steering and handlin......now its no autocross truck but shit its not bad. Ford front suspension design sucked to begin with so its no loss to me
