bigbrakes for 93 toyota?
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
who all offers bigbrake kits for the 89-94 toyotas
scotto79
I came across one site that had them, but lost it when my computer crashed.  But 2005 Mustang GT brakes are the same height as the stock Toyotas.  I'm starting on a set of 05 Mustang rotors when I get back from Vegas.  I'm setting the rotors on the back of the Toyota hub, and machining the Toyota hub bolt holes larger for the GT rotor.  The only real reason for going through all that work is these can be had for $150 or so with brand new rotors, calipers, and pads, while the Toyota big brake kits were around $1000 or so. http://www.newtakeoff.com/mustang_gt_front_brake_caliper_and_rotor_set_2005-2009.aspx Hope that helps a bit with some other options.
bodydropped85's avatar
bodydropped85
interesting. what all has to be done?
e10pvmt's avatar
e10pvmt
there is a BBK of sorts listed on toyotaminis.com that uses 4wd brake calipers, wilwood hats and rotors and a bracket available from one of the forum members....i am using this kind of setup for my 4runner except i am using wilwood dynalites and making my own bracket.....i have a set of hubs for the toyotaminis setup that i want to get rid of but no one seems to want them.....i want to go to a different hat that uses a less exspensive speedway or us brake rotor.....here are the links to the 2 threads...let me know if your interested in the hats http://toyotaminis.com/forum/showthread.php?t=252&highlight=brakes  http://toyotaminis.com/forum/showthread.php?t=291&highlight=brakes
scotto79
---------------------------------------------Originally posted by bagged85interesting. what all has to be done?--------------------------------------------- First the center bore of the Mustang rotor had to be enlarged to fit on the hub then the Toyota hub has to be drilled out to accomodate the larger bolts on the Mustang rotor.
tuckinlugs06
---------------------------------------------Originally posted by e10pvmtthere is a BBK of sorts listed on toyotaminis.com that uses 4wd brake calipers, wilwood hats and rotors and a bracket available from one of the forum members....i am using this kind of setup for my 4runner except i am using wilwood dynalites and making my own bracket.....i have a set of hubs for the toyotaminis setup that i want to get rid of but no one seems to want them.....i want to go to a different hat that uses a less exspensive speedway or us brake rotor.....here are the links to the 2 threads...let me know if your interested in the hats http://toyotaminis.com/forum/showthread.php?t=252&highlight=brakes  http://toyotaminis.com/forum/showthread.php?t=291&highlight=brakes---------------------------------------------what you want for them...wat i really want is the rotors thats on the mazda with the 4's the wavy ones
TOYBOY89's avatar
TOYBOY89
check out my front brakes, wilwood calipers and pads (surprisingly they were pretty cheap) and some modified supra rotor, and custom caliper brackets (these are were all the work was, I have several sets of brackets, email me if you would like some more info.
no1lowr's avatar
no1lowr
Edited: 2/25/2010 12:22:52 AM by no1lowr
 dude. phattys fab! duece is on the luece!!!!!!!!  i think his website was www.phattys.ca  or his myspace is www.myspace.com/tfantini
bodydropped85
what about calipers on the mustang rotors?
