Air Ride Suspensions \  copper tubing
copper tubing
Air Ride Suspensions Q & A
views 2155
replies 19
following 20
truk2low4u   +1y
how hard is it to run copper tubing and how much psi can copper tubing handle?
drpitlo   +1y
I ran it on the front of my old accord becuase of the heat from the engine. Wasnt hard to run and i believe i i ran 100 to 120  to the cyinders but dont qoute me that was 6 or 7 years ago.
IMLOWER   +1y
i only use  copper and alluminum  line  for my air systems  all run at 200 psi  never had a leak
pugz   +1y
Edited: 4/22/2010 11:26:20 AM by pugz
^^^IM WITH POTTER.  THATS ALL I LIKE TO RUN ON MY TRUCKS   200PSI DAILY DRIVEN WITH 0 PROBLEMS
92yota   +1y
where do yall get fittings for copper, and what kind do you use?
IMLOWER   +1y
just regular  push connect fittings  any shop should be able to get them for you
Marcos_65   +1y
Really? I thought you had to use swagelock (sp) fittings?   Learn something new everyday, so just regular brass PTC's huh??
laydsuzu   +1y
^^ yup.
gravity5   +1y
I used it on a couple of vehicles, 1/2 copper line should be good to 640 PSI provided the right fitting is used, which by the way is Compression, and there are specific ones desgined to be used with copper.  PTC's will work but if the line is even slightly oblonged it will leak.
jmzcustomz (jeff)   +1y
What he said above---^I never used Copper on a vehicle but back in my factory working days we used copper line (3/ with about 90 to 190psi in a HIGH temp (like 700f plus)  and it worked great.  It was a rotational molding facility.
