PAINT COLOR SHADE
16 following
rideflat@hotmail.com's avatar
PAINT COLOR SHADE
blackhulk's avatar
blackhulk
HEY I WAS WOUNDERING IF I PAINT MY WHOLE CAB WITH ONE STAGE AND CLEAR IT AFTER FOR EXTRA DEPHT AND I PAINT MY BOX A MONTH LATER WILL THERE BE A DIFFERENCE IN SHADE..ITS A GREEN METALLIC COLOURTHANKS
baggedblue75's avatar
baggedblue75
alright now heres the issue with this.you cant shoot the single stage and just clear it like basecoat.you will have to shoot it let it fully cure sand it with 1000 or 1200 grit usually and then clear over it.now here comes the problem being that yours is a metallic your going to be sanding the metallics in the paint possibly making the color blochy or uneven.then also shooting the rest of the truck at a later date as long as the paint is from the same mix meaning mix enough now so its all shot with the same batch.BUT the metallics might look different in the sun because of different spray times and the metallics not laying the same.i have done what you want to do with solid single stage colors and your right it does look very deep.i wouldnt recommend it with metallic single stage colors
nissandoordragger's avatar
nissandoordragger
first dont sand with 1000 or 1200 before reclearing it will delaminate id sand it with 6-800 grit but you cant on a metallic single stage and i really dont think your gonna get much depth out of doing it like that just base clear it
drag4life09's avatar
drag4life09
some single stages ( depending on the brand ) you can mix a certain ratio to clear for your last coat for more shine and better holdout though i don't advise it. if your going to clear over it you should just use reg base anyway.... Base coat/ clear coat is the way to go. If you like the look of single stage and you want to do your box later, if its not that much later no one is going to tell the difference in slight color fade cause your box is away from the exterior panels. plus a buffer and some polish will shine the outside right back up! If your ride is garage kept and always buttered single stage can stay nice for a while if you maintain it. if the color you want is only available in single stage contact the paint company or jobber store the should be able to cross reference something close in base coat or spray it out and get a camera shot on it. -Brad-
low99maz's avatar
low99maz
As long as u use ppg it will be fine,right brad?
drag4life09
thats right jon! omni all the way with shop line primer. next time ill use a better paint roller when we do your truck maybe i wont get as many runnnnnnnsssssss
low99maz's avatar
low99maz
first off its JOHN........it took us a year to paint the truck for a reason right.....if its not right you know i will sand that shit and respray it!!!!!
drag4life09
is that how they spell it in hell?  aaahhhh your prob already are doing a full rebuild quit using this post to talk smack!
baggedblue75
---------------------------------------------Originally posted by nissandoordraggerfirst dont sand with 1000 or 1200 before reclearing it will delaminate id sand it with 6-800 grit but you cant on a metallic single stage and i really dont think your gonna get much depth out of doing it like that just base clear it --------------------------------------------- 600-800 grit is 2 coarse you will burn right through it.your not prepping it for base again the goal is to get the orange peel out before clearing.its the same as two clearing sessions on a truck,hotrod or custom classic you spray 2-3 coats of clear and sand it flat with 1000 then put 3 more coats and cut and buff.and as for the depth part of it it may not be true with this color but ask any old school painter or customizer if single stage black cut and rubbed wouldnt create one of the deepest paint jobs and see what they say.the clear may not make it deeper but it would give it uv protection.and the clear will not delaminate sanding with 1000 grit.thats the usual between graffic jobs.just think if you had a candy job and you had to sand the clear for flames your going to sand the edges with 600 i dont think so
low99maz's avatar
low99maz
I have always done 600 grit for base and 800 for clear
