Under Construction \  amp/subs wiring and selection confusion
Under Construction General Discussions
views 1160
replies 2
layd88   +1y
so let me lay it out. my brother bought some equipment to put in his project and sold the project. he picked up 2 alpine mrv 1507 amps that were used, but supposedly in working order. he also bought 2 new kicker L7 12''s to run off those amps. the kickers are 750 rms@4 ohms 1500 peak. well, the amps are looking like theyre no good and im trying to figure out what to replace the amps with if they do turn out to be shot. scrambling around the web ive found a whole bunch of info but i figured id ask the guys that run shit like this in their projects themselves. im getting the box built for crown vic wagon they are going in, but am lost at amp selection and sub wiring.
my questions.
can i run both subs off 1 kick ass amp? and what amp would that be? ive seen posts on other sites about running 2 4ohm subs off 1 amp at a 2 ohm load, but get lost in the techincalities. do 4 ohm subs need to be wired at 4ohm loads on the amps? any info you guys can provide would be awesome
Blitz Noma   +1y
Edited: 5/16/2011 12:24:09 AM by Blitz Noma
you can wire 2x dual 4ohm woofers at either 1ohm or 4 ohm.
i'd say look for something that does 1500rms watts at 1ohm.
whats ur budget?
this is a great bang for the buck amp.http://www.audioque.com/AQ1200D-Amplifier_p_30.html
lowrthnu92   +1y
:TUP::TUP: on the audioQ
depending on you budget look into Rockfords new Constant Power amps the T1500-1bdCP
or Sundown's SAX-1200D or SAZ-1500D
