wheel pics
wheel pics
low95xlt
does anyone have any good pics of there wheels from the 88-98 wanting to see how much camber you guys have
E
ec_dually
you wanting ride height? or layed out
low95xlt
layed out i will post up mine in a few
tofnlows10
wheels are 100% straight..but u get the point sorta..
bdydrped's avatar
bdydrped
you got huge camber... if thats what you're wonderin? it not your ranger
low95xlt
you think my uppers are to short and casuing the camber?
liljlowrider's avatar
liljlowrider
here the best pics i could find.. almost NO camber with stock arms and lower spindles
low95xlt
looks like ditching the upper a arms then thats what i needed to see
lockone's avatar
lockone
Looking at Lil J's wont help you any. LilJ's is a dually (suspension makes wheels sit farther outwards which reduces camber) with the wheels sitting almost outside the fenders and it is just framed.
Yours being a single wheel with a negative or very low positive offset wheel sit inwards more and causes the articulation of the suspension to be shorter, which == camber. If you took your wheels and suspension and put them on another dually it would have the same effects.
Here is a pic of my old Blue Caddy truck. My wheels had to camber inwards almost like yours do to clear the fenders when it raised up. Your situation is almost the same.
Only way to lose the camber is to install uniballs or raise the upper control arms. Doing this will reduce your tolerances between the tire and fender and may cause some clearance issues.
liljlowrider
so basicly lock what your telling him is to BUILD A DUALLY.
