Where can I find stainless flex brakelines for my 89 GMC crewcab dually(boxstyle)?
thaks in advance..
-rob
jcampbell1180
Did you try LMC? They got all kinds of stuff.
pig rig
LMC only has brake line kits that fit the 3/4&1/2tons I'm on this quest also
maz89
Check with a local 4WD Lift kit Installer or Dealer, the stainless steel flex brake lines are commonly used in the kits, they should be able to find you some.....
jcampbell1180
^^^ Oh yeah. Duh.
jcampbell1180
Is there a difference between the 1 ton and 3/4 ton lines? I would think it would be minimal if any.
pig rig
yea the bango fitting on the caliper end is different I can't remember what the defference is but I do remember it play hell to get mine together when I swapped from 3/4 to one ton
jcampbell1180
^^^ Ah, I see.
landscrapers
yea i called lmc and they were clueless.. uhhh we dont have dually parts but we have crewcab parts will this work??? NO LOL
I called classic tube and theyll make me a set if i send mine to them for about $40 per flex line.. may just have to do that.
