3 Wheeln....
3 Wheeln....
FN
f n lo
hey,
k so im just getting ready to do my bag setup and get everything installed... i dont have plans on hoping or anything liek that, i started off just wanting to drag, and id be happy, but i was wonderin ghow much work and what has to be done to 3 wheel a b-22??? any help would be great....thnx...
slammed83mazda's avatar
slammed83mazda
depends on what you bought list the specs on what u got that ur putting on ur truck
FN
f n lo
engine driven compressor, 10 gallon tank, 3/8 valves, 3/8 ported phoenix bags, and 1/2 inch line.... from what i noe thats what im doing, i still have to order the valves and lines.... i havent bought a fourlink or anything like that..so i thought before i make my mind up some inpout would help....thanx
FN
f n lo
anyone willing to help???
FN
f n lo
Come on boys!! someones gota noe what type of link setup to run, anyone have pics???? i need to get this figured otu so i can order my parts....
vidraggin's avatar
vidraggin
Im not sure on what all would exactly have to be done, but bags are a whole lot more soft than say hydros or cylinders. I havent actually seen anyone 3 wheel on bags, but Id say that you could do it with the right psi. What kind of psi, Im not sure, but those AIM phoenix bags are supposed to handle some pretty high amounts.
FN
f n lo
wel i want to figure something out, so if anyone knoes if this can be done, and how, pleez let me noe, i want to start figureing out my setup....
madbagger's avatar
madbagger
go to layitlow.com and check out the air suspension forum cause there are a few topics on this
FN
f n lo
thnx for the link im gunna check that out,but does anybody noe what i have to do, link wise in order to acheive it with bags??? and can anybody explain what a "chain" does??
thnx guys!!
slammed83mazda
i recommend a 3 link set up/super piviot or an adjustable end on the wishbone so you can get that extra lift, and its all about psi, 200+ is recommended and chaining means. like in the front you would weld one control arm to another with chain so you can hop your front end without pulling ur ball joints apart and ur bags and in the rear and weld chain from ur axle to ur crossmember so u can hop or not pull ur bags apart.
my buddys 94 s-10 kicking a 3 wheel on air
as you can see his wishbone set up coming off the axle. he has updated to an engine driven compressor now
you dont have to have this extreme set up to do it, but its all about ur psi and lift u get
