Pissed
pontiacman@gmail.com's avatar
Pissed
pont's avatar
pont
ok so i got my 92 all back togather and running runs pretty good got to fine tune the timing but the dam thing is leaking oil from somewere i dont think its the front seal cuase the timing belt is not covered in oil but it leaking pretty bad. i lost almost a half a quart of oil only driving 4 miles and letting it run for about 10 min. so yea im pissed
nytrdr24's avatar
nytrdr24
where on the motor is there evidence of the oil coming from?
pont's avatar
pont
not sure its all over the intake side (oil that is) im gone go and wash it at the car wase that way its clean then drive it home and see if in can localize i hope its nothing major. other than that it runs pretty good
nytrdr24's avatar
nytrdr24
what have you done to the motor, was it rebuilt?
if so did you have the head checked to see if it was warped, & did you
use new head bolts to put it back together?
other than that, you might have an oil passage stopped up,
or the head gasket didn't mate /seal up right and is causing the leak.
hope it's nothing major!
pont's avatar
pont
just a oil pump everything eles was left as is but since i got it not running it could be anything will have to look into it more
FN
f n lo
kool man let us noe...
blare
no no pissed is when almost every damn bolt hole and bolt on your damn motor is stripped. Thats when you want to throw a fuckin wrench.
pont's avatar
pont
well it appers to be leaking from around the oil pump guess i ether over tighted the bolts or did not get them tight enough ill have to take all the crap on the front back off and check i hope i dont have to pull that oil Pan again
lukeinva
Been there!!! YEAH that is pissed!!
nytrdr24's avatar
nytrdr24
MAKE SURE YOU USE A TORQUE WRENCH, AND TORQUE THE BOLTS TO THE SPECS IN A SHOP MANUAL. THAT WAY YOU KNOW THAT YOU WON'T STRIP THEM OUT AND CREATE MORE PROBS.
