djmojo
Ok so I got a tach cluster for my truck installed it. Everything worked fine, Speedo worked fine tach was accurate temp and fuel gauge worked fine. I filled up the tank and the gauge showed full. Drove the truck around for like 2 weeks. It never even crossed my mind that after about 320 miles I still had a quarter tank (or so the gauge said). At about 330 the truck just shut down... I was like shit... now what. Then I noticed I went 330 miles since the last gas stop... so it clicked! I’m out of gas! But the gauge says a quarter tank still...
I fill the tank and the gauge shows empty (below the E line) I took the cluster out. Took it apart cleaned it and installed it again. I set the gauge to full before I put it back in and the needle held there no problem. As soon as I turned the truck on the gauge went back to its previous spot, bellow E. I thought it was the gauge but I used my old cluster and it did the same thing...
What could be the issue? Does the gas tank have a float device or something and could have broken? Is it a replaceable part? Has this happened to anyone before? Thanks allot for the help in advanced
