General Discussion \  thanks alot arse holes!!!!!
General Discussion
views 1731
replies 17
following 11
toddluck   +1y
well after reading through some posts on welding i guess im not going to attempt my notch,4linf and bag set up on my own!!!!! i was gonna jump in with both feet and do it over the winter but my welding skills are minimal.....and the saftey facter keeps comming into play and i dont wanna hurt my self or anyone else on the road..lol...so the new plan is
i am going to do a stock floor body drop im gonna cnotch my frame but im gonna use a 4 inch pipe cut in half for a lil more axle travel and do a ball joint flip....im just gonna run my air shocks for now and im going with the main leaf with the second leaf flipped upside down ontop of the main
devb22   +1y
Don't give up dude?
Sent you a PM.
Dev
toddluck   +1y
ok ill go checkit out ..im in no way giving up dev just putting it on hold until i get some welding under my belt......i figure the body drop i can handle..lol
slammed83mazda   +1y
I think you need to start out on a c notch or something small man before just jumping into a body drop. Or get some little pieces or steel and test them on there this is what I did before I ever thought about welding anything serious and it helped alot and I knew I could trust my welds
toddluck   +1y
im pretty good at sheet metel welding ...body panels and such that i could handle im 100% confident in that but dont wanna take on structal stuff until im 100% sure i can pull it off....dont get me wrong it WILL get done i have three frames to play with and practice on..they were going to the scrapper anyhow so ill just keep them around for crash test dummies so to speak
gravity5   +1y
A stock floor bodydrop requires welding the frame???? unless you are going to chanel the body like they did back in the day... I would do a notch long before a stock floor.
toddluck   +1y
the only frame mod to a stock floor is the frame horns for the radiator ,,,,,right ,,,i can handle that much
sudkrap   +1y
When you do a stock floor bd you basically make a new frame that fits under your cab... or hack up the existing frame so your cab and the bottom of the frame is flush (not recomended)... I dont know how you would do that with out welding...???
Maybe you want to do a custom floor body drop???
toddluck   +1y
i want to cut the floor back of cab fierwalls drop the cab and reweld everything back up with filler plate.....sud i was talking about frame welding sheet metel isnt a problem
sudkrap   +1y
My bad, i meant to say welding "on the frame"
