anyone know how to get around emissions in az
mrkfannin1@gmail.com's avatar
mark13's avatar
mark13
any ideas?
9
91_2600i
I'm sure Cusser will be along soon with his Emissions Cheat Sheet!
sincitylocal's avatar
sincitylocal
Cusser doesn't have a cheat sheet... he lives(or is registered) in a county where they don't have emissions testing.
Cusser's avatar
Cusser
Well, the Cuss lives in Yavapai County, Arizona, where there are zero emissions.
Mrs. Cusser lives in Maricopa County, AZ, which has some of the strictest emissions testing in the country, goes back all the way to 1967 models. So her Yukon and my youngest's '98 Nissan undergo testing as they are registered by her (if youngest's Nissan fails the test in January, I'll "buy" it and register it as mine, but I apparently fixed its check engine light 3 weeks ago by simply unplugging and plugging back in the throttle position sensor).
First question is: are you failing because of high levels of HC, CO, or NOx, or because some inspector can see capped-off vacuum ports because you now sport a Weber?
What I used to do for my B2200, my 1971 VW, and 1970 VW was to clean or replace the spark plugs, new air cleaner element, points/adjust valves/ ignition timing on the VWs, and lean out their carburetors and increase the idle speed to about 1100 to pass.
In fact, with our carbureted 1984 Jeep Cherokee, I had failed emissions about 1990 and a repair shop looked out the window, said I needed a new carburetor without ever leaving the desk - that was amazing diagnostic skills, they wanted over $400. I opened the Yellow Pages, found an emissions repair shop, guy says he gets me to pass for $25. I go there same day, he inserts a test probe at idle, he pulls off a vacuum hose to lean the carb, then adjusts the screw to bump the idle up to about 1100 rpm, tells me to go get tested, then come back, he'll set for previous/best driveability, take my $25. He doesn't know that I saw/understood exactly what he did, but I did return and pay him. Anyway, I got home, and painted that vacuum hose and carb screw red so I could readily do the "fix" myself for the next test.
OK, other tips. Makes sure the engine is fully warmed up before going to the test. Don't run the AC before the test as that makes the underhood temperatures higher, even though the temperature gauge might still show the same. You need your EGR working/connected most times to pass the NOx test. Most garages have emissions testers, they just don't have the wheel dynamometers to simulate loaded driving conditions. But engines typically run dirtier at idle; in fact for many years, older vehicles were only tested at idle here. And before that, anyting that reached 14 years old was no longer tested. Both my VWs and my 1979 Toyota ruck had been exempt before the state decided those three were causing the state's pollution.
Cusser's avatar
Cusser
OK, I know I'm "quoting" myself. Is this for a Mazda truck, or just "in general" ?
I'm adding here that a few folks here have welded a catalytic converter onto an exhaust flange pipe for their old VW's exhaust, and then bolt that on for the test, then unbolt it and save it for next testing. So consider maybe adding an extra converter or a working converter just for the test.
Those older ones get tested every year, newer than 1980 only every two years.
mark13's avatar
mark13
thanks for all the info Cusser, its for my mazda im going to take it to emissions this week not sure how she'll do
but i did weld in a new cat and just got a rebuilt carb so
i hope all goes well.
sincitylocal
Check this out Mark.
befarrer's avatar
befarrer
If you have access to a dwell meter, it would be a good idea to check the dwell, it could indicate a problem you cant see that might fail your test.
Also, has anybody had a B2200 with efi tested? Are the emissions lower? I know they have no EGR from the factory, and only 1 cat. I dont have emissions where I am, but I would fail anyway since I have no cat.
mark13's avatar
mark13
thanks SinCity, so much good info
Cusser's avatar
Cusser
I would guess that in general a fuel-injected B2200 or B2600i would do much considerably better on an emissions test than a carbureted vehicle. Especially compared with the infamous B2200 carb !!!!
