Page 1 of 4
Mazda Engine General \  2200 engine rebuild
2200 engine rebuild
views 4076
replies 39
following 7
88lx   +1y
Unless I can find a good motor local,I'm looking to rebuild mine. It runs smooth and purrs like new, but smokes like so many others I've seen.motor is super clean and dosent leak a drop. Guess I need to get off my butt and do a compression test to help determine whats most worn. Comments and suggestions?
baggedb22   +1y
I have a good motor and tranny where ya from?
88lx   +1y
Atlanta,GA area
baggedb22   +1y
Oh damn im in PA shipping would be pretty expensive!
drpdmazda   +1y
you probably just need to take the head off and send it out for a ring job, and valve job while its off, and might as well get new lifters too
should run you in the ball park of 200 with parts and labor
baggedb22   +1y
Either that or it needs rings....
baggedb22   +1y
Did you try putting new valves seals in it?
drpdmazda   +1y
dude, did you read my last post at all???? where i said get new valves and rings???? lol
baggedb22   +1y
Yea but mazda's sometimes smoke just because of worn out valve seals why do all that work when all u gotta do is replace the valve seals...Do you even no what a valve seal is????
88lx   +1y
Anyone know the what the compression should be in a healthy cylinder for the 2.2.
