is their much difference between 2.0 and 2.2l
12 following
roknmotor
i was curious i just bought another b2200 and the motor is shot, i found a good running 2.0 out a b2000 i was just wondering if there was a big hp difference between the two engines, cause i know there is not much power to begin w/ on the 2.2l??
8
89b2200
Ask Mark if he noticed a big power loss.
He is now running a 2.0 liter with a Holley in his 92 B2200 truck.
mazdizzle
I have a 2.0 in my 2200 and I couldn't tell much of a difference other that the 2.0 doesn't smoke like my old 2.2 did. Either way neither of them make much power.
speedster93b's avatar
speedster93b
i have heard however that if you put a 2.0 head on a 2.2 it'll give more hp, simply because of increased compression. i don't know for sure, as i've never tried.
pont's avatar
pont
nope there the same head nothing is differnt from them if my 2.0 did not smoke i would drop it in my 2200 it smokes alittle to
limequat's avatar
limequat
For the record...
B2000
80HP @ 4800 RPM, 110 LB-FT @ 2500 RPM
B2200
85HP @ 4500 RPM, 118 LB-FT @ 2500 RPM
roknmotor
sweet guys.. thanks for all the info and feedback!!!
speedster93b
so what IS different? stroke? cyl. bore?
nytrdr24's avatar
nytrdr24
85-87 b2000 1998 cc, 86 mm bore, 86 mm stroke
87-93 b2200 2184 cc, 86 mm bore, 94 mm stroke
pont's avatar
pont
the deck hight on the 2200 is taller allowing for the longer stroke
kia swap
last post by Brody +1y
51
