Mazda Engine General \  have a question
have a question
views 1269
replies 11
following 5
mazm   +1y
my truck just started doing this, when it is in between 2 and 3 grand it starts cutting out and acting up, my transmission has a bearing going out in so i don't if that has anything to do with it or not
blue crush   +1y
what do you mean by cutting out????????
Are you losing power or...................
Justin
mazm   +1y
i think that it is my timing, it starts to bog down and miss
nytrdr24   +1y
is the engine missing, or is it just bogging down. if its missing it could be the timing, but if it is just bogging down that bearing could deff. be the prob.
maz   +1y
fuel filter or in tank pump screen if you have an intank pump
blue crush   +1y
i second that........
Justin
mazm   +1y
my fuel filter is clean, i am gonna put my other transmission in and see how it runs then
nytrdr24   +1y
since the filter is clean, have you hit it w/ a timing light? also does it only do it while pulling a load on the motor (driving down the road), or will it do it while sitting & idling?
mazm   +1y
i haven't used a timing light on it, and it does it going down the road
nytrdr24   +1y
double check w/ a timing light, it would sux to pull the tranny & it be a timing issue.....but w/ it doing it going down the road is sounds to me like that bearing in the tranny is your prob.
good luck!
