Mazda Engine General \  trying to put in fuel cell in b2600i
views 1166
replies 14
following 5
draggin89   +1y
i am trying to put this in. and i need to know what fuel pump to use . it is efi what psi do i need.do i need more than just a fuel cell and fuel pump.
schardbody   +1y
stock pressure is 38-42psi. one of the holley inlines will work excellent.
devb22   +1y
I believe the Fuel Pump you are looking for is the Holley Blue
Try that link out?
Good luck!
Dev
joemazda93   +1y
So what do you do because the FI have 2 supply lines and 1 return line dont fuel cells only have 2 ports tell me if im wrong
devb22   +1y
Any Fuel Cell that I have seen has 4!
2 on top
2 on the bottom(side)
Hmm....
Dev
devb22   +1y
And you will need more than just the Fuel Pump and Fuel Cell to get this thing plumbed!
You will need either some hard line and or braided hose! You will also need AN Fittings whether it be -8AN, -6AN
You would be better off if you put in a Check Valve in the system and possibly a Second Filter inline!
You can get all this stuff relatively cheap from Summitt Racing!
Good luck!
Dev
nytrdr24   +1y
devb22, that holley is only good for 14 psi, it won't support the efi on his mazda......good shot though....
just as an example, here is one that ought to work
and a regulator
devb22   +1y
Thanks for the correction!
Sorry for the misguidance!
Dev
draggin89   +1y
my fuel cell only has 2 outlets and 1 vent will this work
draggin89   +1y
can i use my vent for my return line and drill and tap a hole for a fitting for a vent.
