Mazda Engine General \  b2000 engine in b2200
views 2643
replies 13
following 6
hhalo23   +1y
hello,
i bought an '89 mazda b2200 with a b2000 engine put in it. i didn't realize the complications this would include.
symtoms:
- engine runs very rough and won't idle unless of course idle is cranked way up.
- mileage is very poor
- when i rev it up and then release the pedel, it wants to die for a second or two
i have replaced the carb with another used original one, and followed all the b2000 vacuum diagrams.
could this be a computer issue? is the engine just not getting along with the 2200 truck computer system? if i put a weber on it, will these issues be resolved?
any ideas would be appreciated,
thanks.
maztang (ryan)   +1y
could be the computer but i would say trash the stock carb and get a weber. you will not regret it! it sounds like all your problems are coming from that carb though.
sudkrap   +1y
It could also be something a little more simple, like spark plugs and wires.... my 2 pennies..
maztang (ryan)   +1y
yep.
nytrdr24   +1y
doubt it is the computer, either a carb or timing issue.....i'd do a good tune up, and set the timing correctly & see if that has any influence, if not, more than likely it is the problematic oem carb.....
hhalo23   +1y
well, from all the questions i've asked on many different sites, it sounds like these stalk carbs are a pain in the... i have done a full tune up, including plugs, wires, distibutor cap/router, filters, etc., and set the correct timing already, but it didn't fix the problem.
off to WEBER i go...anyone know where to get a good deal on one? could i find a used one? is the weber K675(32/36 DVEG) the one to get?
thanks for the help.
nytrdr24   +1y
they have the best prices that i know of other than e-bay, which you get what you pay for.
to answer your q about which one to get, here is a link to a page on their site
with that in mind, i have heard of probs installing the 34 as far as the throttle cable is concerned, but the 32/36 or the 38 are good to go.
keep in mind that if you have to get your vehicle visually inspected, you won't pass......
hhalo23   +1y
thank you very much for your help.
mazdatweaker   +1y
post deleted
Post was last edited on May 14, 2009 03:05. This post has been edited 1 times.
hhalo23   +1y
hey, thanks for the tips. there is a chance that both carbs are bad because they're both used and old, but if i can get away without spending the $350(CAN) on a weber, it'd be nice to do so for now.
i have taken the truck to a guy who owns 7 of them, it's all he does, and he tried adjusting the carb. he also found many wiring problems. he told me to try the weber.
i guess i'll jump into those wiring diagrams and see what i can find(what fun!) to do with this computer ground.
if i were do go with a weber, would i be free of all the computer crap?
