Mazda Engine General \  welding to valve cover?
views 1536
replies 16
following 8
laydoutb26   +1y
hey i was wondering... when i do my engine to match my old school feel i'm goin for... i was thinkin of welding some rails or somethin to my valve cover for a "finned" valve cover look.
can u weld to a valve cover? if so, how?
speedster93b   +1y
our valve covers are cast aluminum. you can weld to it, but good luck making it look good. if you are going to go that far, just make a one off valve cover. it'll be way cooler.
laydoutb26   +1y
how
toddluck   +1y
you could prolly do some glasswork over your stock cover
laydoutb26   +1y
that would get too hot right?
toddluck   +1y
dunno...it was just a thought
immortal1 (linn)   +1y
Good question - valve cover should not get much hotter than the engine coolant which would be less than 200 degrees. Powder coat works great on all engine parts except exhaust and it will handle 400 degrees.
Bondo on a black car works fine in Arizona out in the sun - thats gotta be at least 140 to 150 degrees. I would say give it a try! If you don't mind a painted valve cover it could be a cool mod!
hex0rz   +1y
OR you can always get an aluminum welding kit for your welder and do it that way... IF you have a welder...
You could also go to the hardware store and pick up aluminum welding rods and use a torch to weld it on...
Although torch welding is a very tricky thing to get good at... But it would be your cheapest alternative!
maztang (ryan)   +1y
jb weld it haha
laydoutb26   +1y
were u talkin about brazing it?
